BG DCI
Hi guys,
The only things needing doing on my Ph1 172 is the exhaust needs changing soon.
I believe however that my Ph1 only has 1 lambda sensor on the cat? (hope this is making sense, I know about but not huge amounts)
I understand also that Ph2 after market exhausts will fit a Ph1 but as long as you have '2' sensors...
Did later Ph1's come with 2, or can you just purchase a Ph2 cat? but then what about the other sensor ect.
It all got abit too much searching so thought I would as for some advice.
Thanks alot
Liam.
Thanks alot
Liam.
