pretensioner wires, under seats
  Pug 306 GTI6 & 205 GTI6
ok, every now and then i get the air bag and serv light on,
which i assume is the pre tensioner wires under the passenger/driver seat
is it ok to unplug these???
only asking as i was going to cut the loom off and put some new wires in
bad idea? or not?
and will the air bags or anything else go off if i unplug the wires under there???
  vers le haut doigt milieu
Sounds like a good idea to me, they come on and off all the time for me it would be better to have a decent conection. It wont deploy the airbags
cool, so i guess as long as the ignition is off it's ok to unplug
there are severak wires under there,
do you know what wire does what?
  Megane dci 130
Dissconect the battery for half hour if I were you before doing any work.
Look under the seat on the passenger side and you will see a grey connector with a blue and brown wire. Just cut them out of the connector one by one and solder them together and insulate with heatshrink.
When done, look on the driver side and do the same with the brown and blue wires. You will also notice that there will be more wire in the connector on the drivers side. Just cut out the blue and brown and when done re connect the connector.
Hope this helps.
so "normally" it's just the connectors that cause the issue?
and not the actual wires?
