Printing templates / Contact sheets
  "Navy" N17 TWO
I am trying to work out how to make a template in CS4 (or Lightroom 3 if possible)
I need to be able to print multiples of 37x47mm on an A4 - like a contact sheet
The images will vary for this from time to time - so drag & drop would be awesome but no idea how to set it up :S
Thanks in advance
Trev
Ay Ay Ron
I looked on YouTube when I needed help making contact sheets in light room.
The only thing is, it took absolutely ages to convert them (probably due to me not lowering the image quality)
Apparently in cs 3 there is an option in one of the top menu's to make contact sheets too so might be similar to cs4. YouTube is your friend for that. Should be able to find what you are asking.
Hope that helps.
  "Navy" N17 TWO
Yeah has the option to make a PDF in bridge, but when you set your dimensions and print it - they turn out far from what they are set to :S lol
