Project ph-black
  PB172
Got any pics on here of ya new 172 Rage?
I love tax rebates haha. What tyres you lookin at getting for the clio Payton?
  Clio ph2 172
Im thinking yoko paradas , or r888 ?
Ive got t1-r on the polo and i think they are a very soft compound Class tho :)
Struggler
  Ph1 track 172
looks like a pretty good project mate!! youre doing similar mods to my plans!
but seems silly to fit arb, and topmounts,
with ktec coilies?! theyve not got a very good reputation!
  Clio ph2 172
little sneak preview :0 what you guys think ?
to complete the handling i now need :
polybushed wishbones
polybushed anti roll bar
front 7mm spacers
fit my camber shims so -1.0'
rear 10mm hubcentric spacers
fit yoko paradas 195/50/15
change front camber to -1.4'
then get a full geo setup anyone know were to go around cannock area ????
  Clio ph2 172
i think im going to bring her out on my 20th which is like 21st feb so not that long now peoples :) engine will be running early january no matter what , got a few bits to buy this month like
polybushes,
exhaust hangers,
couple of lil things :)
its deffo coming out as a subaru pi**ed me off last night, was half way out overtaking a car in the polo with my indicators on, and a subaru wrx like bullied his way through and shot past me the di*hea*d, and i just got thinking he wouldn't of done that if i had the clio out :) i would have pushed him down the road lol !
  Clio ph2 172
Everytime i walk out my house it just looks so evil just sitting there on the drive haha.
also im thinking of doing the brake Callipers yellow what you guys think ?
  RenaultSport 172.
Keep them black...;)
Keep the different coloured calipers to the 4+pot boys ;)
  Clio ph2 172
right bit of bad news today,
all started well went to euro car parts got the exhaust hanger , come back jacked the car up, started to take pulleys of the cam so we could refit the rocker cover then i noticed that the valve springs were down on two nearest the driver so on further inspection manifold off, got a mate with me to help he thinks the same as me two bent valves anyway ill let the pics do the talking......
View attachment 68614View attachment 68615
heres a few pics of the exhaust mount
few pics of the car poor thing
View attachment 68624View attachment 68623View attachment 68622View attachment 68621View attachment 68620View attachment 68619View attachment 68618View attachment 68617View attachment 68625
ohh and the other bit of bad new is that , went to a place called motormania too get some tools , got quoted £103 for headset and headbolts thought great although they cant do the valves, but gsf want 130 for the lot. got the tools home thought right started to take the head off un-did the outside ones fine but 4 bolts in the middle have now rounded off. my idea to weld a nut /socket to the bolt might work. has any1 else got any ideas ?
  secret
Thats w**k mate, u can get sockets that remove rounded bolts but duno if u can use them on headbolts :(
  Clio ph2 172
Here is what i believe to be a full spec list for 2012 -
Engine
  • KTR 172 decat pipe
  • KTR 172 supersports stealth system - done
  • CNC matched inlets
  • ITG air filter with proper cold air feed
  • KTR billet lightweight flywheel 5.3kg > 3.7kg
  • KTR 438 high-lift cams
  • KTR custom remap
Susspension
  • KTR coilover kit - done
  • KTR solid top mounts - done
  • KTR full engine mount kit - done
  • Powerflex - wishbones,anti-roll bar and dogbone mount
  • Whiteline rear anti-rollbar - done
Brakes
  • Front -Brembo high carbon disks
  • Front -Ferodo ds2500's
  • Rear - KTR uprated rear dimpled disks
  • Rear - Ultimax pads
  • KTR braided hoses
  • Motul RBF660
Tyres and Handling
  • Rear camber shims 1.0 degree - done
  • 1.5 degree of negative camber
  • 1.0mm of toe out
  • Yokohama parada spec 2 all round
Struggler
  Ph1 track 172
our specs are nearly identical other than the engine! :)
only differences is
Gaz coilovers,
Carbone Lorraines
and gen rear discs and pads!
seems like a good set up!! but unfort engine work is slightly out of my budget atm, im just going to take it out and give it a good service and a lick of paint!!
