Rear axle bolts - Another way?
So the s**t design of the 6 captive bolts (3 each side) have meant I had to cut 1 off.
I spoke to Ren parts direct to sort a replacement and they're very expensive.
What bolt can I use to replace them with? preferable with a head on top so a socket can be put on
Cheers.
  Clio 182
Nut and bolt through from the top, m12 I think it was...had one shear when undoing one of my subframe bolts to fit an anti roll bar.
Knock the old one out and away you go!
Legend, Renault wanted £35 for 1 vertical bolt, and 2 horizontal bush bolts - f**k that.
  PH2 172
Size what you require,and contact ALFAST in Luton through their website.
I recently restocked my usefull nut,bolt,washer,allen screw tray with about 150 items & it came to £6.
yeah I need to get one of those, get them through trade?
