Recommendation for alignment settings
  Clio 172 RS ph1
Hi there,
Looking for a wheel alignment settings,
The car is mainly used for track,
Car setup:
Bilstein B14
PMS v2 solid top mounts
Nankang ar1
Rear is lowered to maximum
And front somewhere around 40mm
If needed I can add front camber bolts
I want the car to be a little bit more sharp over the corners.
All front suspension parts are new.
Thanks in advanced
Udder Nonce
I Park Like a C**t
Dont even bother going for alignment without some front camber bolts. You basically have zero adjustment otherwise.
DomP182
  ph1 172, Arctic182
Asking tyre places around me to set up camber bolts is amusing, they only understand winding a track rod end in and out. Tractors dont have adjustable camber seemingly.
  • Like
Reactions: MLB
