Removing bump strips
  Clio 1.2 16v
Hi all, i want to spray my door bump strips black to match the car. I was wondering how easy it is to remove and then replace the bump strips? Does anyone know from personal experience?
James
very very easy, Use the search next time.
Open the door, where the lock is on the inside of the door there is a black circle, take that cap out press the pin in thats down from the hole and slide the moulding to the back of the car. The rear quarter ones just slide forwards. done.
Liamm
  Astra GTC
read a thread like this other day
you open the door and slide the front ones back after taking a cap off in the door, and the rear ones just slide forward, the first time you do it will be the hardest because of all the grime and muck under there.
hope this helps :)
**beat to it lol
