Renault 5 clutch
hardy
  Clio Mk1 Track Proj
Will a Renault 5 clutch fit into a 172. I know the gearboxes are the same bolt holes but will the clutch fit on the 172 flywheel?
From reading up they fit on the 16v and williams as an upgrade.
Cheers Josh
Adey.
nope 5 clutch is 200mm and the 172 has a 215mm from memory, the late volvo 440 turbos had a 215mm clutch and will be more man than the stock 172 clutch if your looking for an upgrade
