Ultra Red Clio 197
For those of you that have built 172/182 Reps can you tell me how you fitted the RS side skirts? I also have the full kit including front bumper, wings and archliners before anyone says I need them! lol..
I have 16 of the plastic brackets (8 for each side if required) and plan to drill the sills then rivet the plastic brackets on. Though by drilling the sills this will open it up to water and then rust setting in so planned to use black silicone or under seal to seal the holes.
The only thing im not so sure on is the best way to get the brackets positioned in the correct place to match the little bits that stick out on the reverse of the side skirt. How did you go about measuring and spacing them correctly?
Im going to be doing this next weekend so appreciate any thoughts or advice that anyone can give!
