RS tuner
  Ultra Red Megane 225
Is it possible to "borrow" from someone? i.e. buy unlock code and just use their hardward to plug in?
Or would it be better to spend th emoney on a proper map?
Just fitted decat exhaust and i want to be sure everything is perfect, fuel usage sems to have gone through the roof!
Da
  Less
You can use one for fault diagnostics without the need for unlocking codes etc.
If you want to use it to program a new Map on then you'd need to unlock it to use on yours and then again to give back to whoever you borrowed it from.
