rumbling on a 172
  197 ff albi
got a phase 1, when i plant the throttle a bit and i dont mean dump the clutch i mean put the boot down when im moving theres a rumbling coming from passenger wheel, anyone got any ideas or had the same?
  Megane Trophy, Golf
Wheel nuts, bearings, ball joints, broken spring! you will have to have a look. Jack up wheel and check for movement. Check steering rack to ;)
  197 ff albi
cheers guys i hope it is bearings, il get em done and see if it sorts it, ive had bearings go before on other cars this one sound louder hope its nothing sinister :(
  197 ff albi
took wheel off on weekend and theres slight play in shaft so i think its CV joint, play is about 5mm forward and backward,
