after spacers for a mk4 ibiza cupra tdi and confused between the bolt through type using longer bolts or the bolt to hub type that use your original bolts
im leaning toward using the bolt to hub type ones that involve bolting the spacer to the hub then using OE bolts to bolt the wheel to the spacer
however will the OE bolts not "bottom out" on the spacer and not tighten up fully ??
using 20mm spacers btw
