Stainless Steel Exhaust Clamps?
  Focus, GSXR1000 & R6
Just had to change one of my exhaust clamps, took me like 30mins and ended up cutting it off, do not think it has been off the 8years the car has been on the road.
Is it possible to get stainless ones that would come off easier?
Or any other tips or advice to help look after it better and stop/slow down it rusting?
Top man thanks :)
Next question then what size clamps do i need for a 1.4 16V MK2 Ph1 Clio?
Thanks!
is this a u-bolt clamp you've had to cut off? they usually have the size stamped on the clamp (might need to wire brush it to find it). failing that (and assuming it's not the bottom part you've cut up), just measure across the top of the clamp
putting things back together with copper grease will help, too
