Steering Wheel Removal?
  Chocolate Orange 172
I have a PH2 172 and was wondering how to remove the steering wheel? I have a retrimmed one I need to fit and was wondering where to start? Cheers
  172 Cup
Theres a couple of decent guides showing you how to do it pal, have a search and you should find them easy.
  330i. E30 Touring.
Simples.
Two clips on back of airbag. Unplug the wire.
Then big T50 (I think) torx screw holding the wheel on. Might need a bit of wiggling/rocking to get it off- sometimes they get a bit sticky.
Chris205
  Many Things
I find it best to crack the bolt off then undo it by a few threads, then wiggle the wheel so it loosens off the splines, you can end up damaging the squib if you completely remove the bolt then rip the steering wheel off
