Clio 1.2 Grande (2001)
Ok so I've got this problem with my dashboard or rear lights. When I have the lights on and I indicate right, the dash light for the rear fog light comes on faintly too. Also if you brake it sometimes comes on a bit. The actual fog bulb in the rear light cluster doesn't come on except when it's supposed to. In fact all the actual lights work 100%, it's just the dashboard that seems to be a bit mental.
I know the 1st top bulb is the dual filament Brake/Rear light
2nd bulb is right indicator
3rd bulb is reverse I guess
4th bottom bulb is the rear fog light.
I've been told it could be a bad earth somewhere so I've replaced all the bulbs and given the contacts a rub with some emery cloth but that didn't seem to help.
I did remove this from the reverse bulb slot. A proper grandad garden shed type repair. The owner before me had obviously broken a bulb but not had a replacement so he polyfillered another one in it's place. Comedy. :lolup:
Anyone got any other ideas?
