Hi,
I've replaced my coil spring, but I cannot get the bolt holes to line up on the hub and shock. Its a good half inch away and almost could do with being compressed.
I've tried full lock in both directions, no luck. The only way I can get the hub and shock in line is directly above the CV boot and its pressing against the rubber boot.
It came off but was under a bit of compression - what's the easiest way to get it back on? It must be simpler than this?
Many thanks,
Kris
Many thanks,
Kris
