Swapping over pedals on a 1.2
  eunos roadster mk1
Had a quick search but can't seem to find anything. Wanting to change from the crappy bog standard pedals to one from a 1*2. Is it a straight swap? Anyone done this before, or is it more trouble than it's worth?
Any help would be greatly appreciated
cheers
  172/1.2/E30
Accelerator is plug&play (depending on cable driven or drive-by-wire). The other pedals are a bit more tricky. Easiest option is using only the pedal covers from the 1*2, drill your pedals in the correct position and rivet the covers on.
  Evo 8 MR
Seriously not worth doing. Your feet slip off the metal pedals when its wet out anyway.
