Sync ical to Outlook?
riz
  Jaguar XFR
Is this possible so i can see my home calendar in outlook?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
The web says:
"For outlook 2016, you want to install icloud on your PC. Once it is installed, it will let outlook 2016 run an "add-Ins" "iCloud Outlook Add-in" to synchronize your ical with outlook in both way. This means you can modify your ical on either outlook or iphone. Then the system synchronizes both.
If it fails, try to close outlook 2016, open icloud, uncheck the calendar. hit 'apply'. Then check calendar again"
https://support.apple.com/en-gb/HT204283
Darren S
Yep - as @MicKPM says - simply installing icloud onto your PC allows this functionality. On my Outlook 2016 install at work, I now have an icloud folder containing Contacts and various Calendars.
