Temp Gauge Fault??
  Elise S1 B&C 140
Just driven home from work and my Temp gauge has started playing up, When i accelerate the temp gauge seems to drop back to 0, when I let off all is fine. Its more pronounced when the engine is cold but does happen a bit when warm also.
Checked all the obvious stuff, oil, water levels, etc and there fine.
If anyone has experienced this or has any ideas please help. I dont fancy the £80 diagnostic charge if its a simple fix.
Rich
  BMW M135i
Probably the coolant temp sensors tis a common thing, does it run a bit rougher like cold start when it drops? I can chuck it on obd and read the sensor data to be sure if you want.
  Elise S1 B&C 140
Mate that would be fantastic if thats ok. Doesnt seem to run any different or perform any different.
  BMW M135i
Hmm could be the dials then I guess worth checking first then, i'm off work this week so can have a look at it for you whenever, shoot me a pm.
