Uprated clutch
  MX5 MK2.5 SVT 1.8 Sport
ahhh, still if the last one lasted then id just buy another standard one. Your looking at 150 + i think and check out OMP, it dosent judder that much
  185lb/ft dCi
need an uprated one ideally mate its gonna be running quite alot of torque, i'll check out OMP thanks mate!
No probs, id evoid a pure motorsport clutch if they make one, judder like mad and have heat cycles that render them usless after a few months of road driving
  185lb/ft dCi
do you know if k-tec racing do one? I tried to give them a call but they are shut now till tuesday!
  185lb/ft dCi
damn it, looks like i'll have to check out OMP but i'll still give them a ring to make sure.
  185lb/ft dCi
Yeah I reckon they will fit from the 80 and 100 its just I think i need something a bit stronger, had it on the rollers and it ran 110hp with 195lb/ft just the clutch was slipping but it slipped with standard map too so its on its way out. Paul said it will run those results all day once the clutch is sorted. Very impressive stats from a 65 if i dont say so myself!
Your a bit of a Dci Pioneer here Macester
Thankyou, just a pitty the dci scene is tiny!
