Urgent Help!!!!
  RenaultSport clio 172 mk2
URGENT!!
I'm in the process of taking my inlet manifold off my 03 172. I've taken most of the bolts out but there is one last one on the drivers side that i cannot get too!! looking directly at the engine its on the left side and bolts along the manifold.. how do i get this sucker out!!
  Clio Mk 1
Pictures would help here
You may be able to get it with some stilsons if you cannot get it with a socket or a spanner
Don't reuse the bolts as they will be waekened by the heat and the cold changes otherwise they may snap off next time.
Matt
Matt - Whats a stilson?? The bolt is under the thing that connects the engine the the car (very technical) on the drivere side...
To make things worse its started to rain!
