Where to buy cat and clutch
  Clio 172 Cup
Hi guyz, does anyone know the cheapest place to get a cat and standard clutch for a clio 172 cup ? Ive heard that the Renault cat is around £900! but ive seen a few around a lot cheaper than that.
  Clio 172 Cup
Hey Fred, 2 reasons :) i had a yozza sport decat race system put on it a while ago and its just becoming a real problem at mot time, somehow my old cat had a crack in it the guy said it looked like someone did it with a saw + im hoping it will make it a bit quieter, one more reason is that it hasnt run very well since i had the cat removed.
How much are you looking for ?
  ITB'd MK1
i think you've got a lambda sensor problem. Probably damaged when the cat was removed, they're quite delicate and I almost expect to need to replace them whenever they're removed
  Clio 172 Cup
ye i did suspect it might be the lambda sensors, its just that ive spent around 2000 quid trying to get that one problem sorted at a quite reputable garage and if it is the lambda sensors i would be quite pissed because they should have checked that. They got me to buy a new throttle body for it and they told me the next step was to try fuel injectors. alas still need the cat, going to sell it when i get it all sorted.
