Hi all,
Can anyone help with Clio 172 Race Cup car?
Long standing problem - it had the Renaultsport loom and ecu on it and developed a starting fault. It just would not start up.
Thought ecu was at fault so changed to Omex 600. Got it started but its never been easy to start since the problems with the Renaultsport loom in December 2007.![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Had it out at Donington park in November. Really difficult to start - turning over and over before starting. In afternoon the car just would not start at all - evenually got it started but was almost going home. Just cranking over and over.
Now trying to start car after winter and it just wont start.
So...car is: Clio Cup Race car 172
Ecu: Omex 600
Loom: Specially made before I bought it loom for the 172. Not a bit of a normal clio loom so obviously not alarm problem etc...
Car loom: The renaultsport loom is still there to work the lights, starter motor etc...
So far I have checked all earths and lives.
Defo getting 12v even when cranking with Omex and switched lives for omex.
Changed TDC sensor today to new Blue type hoping this would cure it - same problem.
On Omex software it shows engine speed - Stat Sync however is Not Synced
Looked in Sync diagnostics part when turning engine over - its registering errors - counting to 4. So its picking up the missing teeth.
Sync is setup with right settings - 2 teeth missing. 57 and 50% time. The table is setup as 5444544454445444454445444544454445 and so on to the end where is has 333 for 57, 58 and 59. I dont know if this is right or not.
Really really, seriously pissing me off - to my mind it should be starting. I think the engine is fucked. With 2 ecu's and different looms I'm not sure if its electrical.
I have changed starter incase it was drawing too much current when starting - brand new starter.
Wiring to alternator, starter and battery checked.
Also did a compression test and all 4 were good and almost identical readings across the 4.
What else mechanical would stop the car starting?
Any ideas really appreciated.
Dave.
Ecu: Omex 600
Dave.
