The big boy 50cal?The PSR sniper feels worse than the first sniper. Which is both surprising and annoying given how long it takes to unlock.
Yeah. Noticeably less velocity than the first sniper.The big boy 50cal?
f**k me you've grinded some you absolute sweatYeah. Noticeably less velocity than the first sniper.
Wait until you see my score 🤣f**k me you've grinded some you absolute sweat
Been tweaking settings a bit. Made a lot of the HUD icons smaller in the game menu (down to 50% to try and tidy the screen up a bit).
Also removed DOF from aiming down sight which was annoying me and applied my FOV to ADS (seems to have affected some other bits too like the main map). Need to find your PROFSAVE_profile in My Documents for that - save a backup first, then change the following entries to the values below, CTRL + F to search for them:
GstRender.WeaponDOF 0
GstRender.FieldOfViewScaleADS 1
Guessing there's a lot more beneficial/performance tweaks available in that file, likely all covered in this guys own profile file that you can download from this vid.
Thanks John, but where is the Ctrl+F button on my PS controller?
On the Beta you couldn’t access the settings in the game itself , is this changed now since release?
I had this last night tooI definitely need to tune the settings down a touch, when I use OBS I definitely notice the frame drop. Plus I’m not capturing some ‘wtf’ moments.
Occasionally when I run/jump over small obstacles I’ll just bounce up into the air 10m. Well this happened to a guy I was mid gunfight with 😂 Also on Iberian offensive I killed someone in an alleyway and just catapulted up into the sky. Had to use my parachute to come down again 😂
that post didn't answer my question. my question is can i change my settings when i'm in a game match, in the beta you could only change the settings in the training area like it's shown in that video.Did you read the post above? Honestly, it’s literally two posts up.
Yes.my question is can i change my settings when i'm in a game
Hmmm , not ideal that way, if you want to do something quick.Yes.
If you’re changing advanced settings you’ll need to reboot the game for the changes to take effect.
Reboot as in pc, you mean. So didn’t mean consoleHmmm , not ideal that way, if you want to do something quick.
No, not really , not yet anyway. Got it home yesterday the new pc. At some point I’ll play games on it , not right nowI assumed you were buying it for your new PC.
