MarcB
Too Many
Currently have a 13" Macbook Pro (Late 2011) running standard 4GB Ram and a standard 500GB Hard drive.
I have seen loads of people talk about upgrading there HD to a SSD and i have watched a few videos on it also.
Now I'm no computer person but from what i can see it makes the macbook run a lot faster would this be the same in my case and would it be a worth while upgrade ?
I also want to boost my Ram from 4GB to 8GB as i have been told this -
"your free memory is a little low, and you have PsgeOuts greater than zero which all means you are running low on memory for the number of concurrent applications running. Some disk swapping is occurring and that should start slowing down the computer. It will also lead to drive thrashing which can csuse more heat from the drive and more slowing down along with the SBOD"
is swapping the RAM easy enough and what would be the best to buy ?
