5 stud adaptors
  172 cup'd extreme
never seen any although you will prob be able to use the hub from a laguna as they use the same calipers on the front , the rears will be a different story , why go 5 stud?
  Hondata'd EP3 Type R
loadsa comapnies make spacers that convert from 4-5 stud, its how the max power lot get big wheels on their car as most of them are 5 stud
  172
can someone give a link to somewhere then? ive got to have a set of wheels ive seen, 5 stud only tho.
dont mind doing it as long as its safe and wont alter anyhing other than the stud pattern
It's safe so long as the bolts are all torqued. in terms of handling/rubbing you will need to select an offset to counter the additional width given by the adaptors.
I've got a feeling H&R and some other german suspension manufacturers do. Best to pick up a dub magazine as those boys are always using adaptors to fit audi/porsche etc rims on their golfs and polos.
