eBay for both.
Abs sensor is Bosch 0265006383
For the rings make sure you get the 44 tooth ones. They have two widths available, you can use the narrower of the two for your 172.
On side note where’s the handbrake switch/sensor ?
Possibly the sensor then or if not, check your brake fluid level.
