Adobe CS3 serial numbers....
how about no theory???!!
This is the education edition if that makes any difference!
ChrisR
You will most likely have 1 license, check the T+Cs but it'll probably only be for 1 install.
  106 GTi
Standard license should allow you to run it on two machines, it did for CS2, not sure about CS3 as I only have that installed on an intel machine and did not bother on the Power PC. If the machines are networked the same copy can not be opened at once.
