Golf gti & 172
My 172 ph2 has been playing up recently, first the eml light came on and had misfire got codes read said it was bank 1 sensor1 fault so front lambda so changed that. Eml came on again a week or so later and developed a really bad misfire, codes read again and it was the same lambda fault plus an injector fault so changed the injectors and plugs and leads and coilpack just to be safe.
Now on Wednesday the eml light came on again immediately on start up and has bad misfire/hesitates until up to temp, once up to temp it gets better until it stops misfiring completley, but as soon as temp drops down below the halfway Mark on the gauge it starts misfiring all over again.
The only things I think it could be now are either the intake temp sensor as this doesn't nothing if unplugged but has current running to it, the map sensor but the engine cuts out immediately if unplugged again has currentor the coolant temp sensor but I don't know where it is located or how to best test it.
Any other ideas or pointers would be much be appreciated and apologies for the long thread
