AG Paint Renovator??
  Golf GTI PP Mk7
Spotted a bottle of this in the shed the other day, dad must of brought it at some point. Anyone used it? Is it any good?
Was thinking I could give the williams a coat of the this, then SRP/EGP over the top.
  Clio 182 Trophy 047/500
I used it on my old car and found it worked ok, its not going to get rid of light scratchs but brings the colour up a treat.
Once you have done that, give the car a polish and seal the whole lot.
  106 GTi
It is a bit like T Cut in its make up, it has a strong cut no matter how long you work it, is strong enough to go through clearcoat even by hand, use with care.
It should remove light marks, but may install very fine swirls that the SRP should remove in using it.
