Air pipe
is it possible to make your own ind kit with samco and stainless pipe? has anyone try it, what size pipe do u need?
  BMW 320d Sport
Ive done it with Samco before, looks good and flows air well, but very expensive to make up custom bends and lengths.
yeah, im thinking of doing this with a viper filter on the end, will save up first though!!!
Email these two companies.
One of them should respond, cant remember which one though.
www.flexibleducting.co.uk
www.flexiblehose.co.uk
I ordered it from 1 of these.
You will need to specify the length you need and the diameter. I can really recommend this stuff !!
I used part of a lorry exhaust and some rubber bends from a jetski exhaust to get the filter in the battery compartment. It works very well in there as its the ideal place to shield it from the heat.
I might try one of those companies if they can export stuff.
Ned.
http:www.mgk.es/clio/filter.jpg">
Air meter thingy? have I got one of those? There is a pipe which goes into the resonance chamber, dunno if thats it, also, theres a rectangled plastic sensor thing which had to be fitted to a metal strip on the header. could it be that?
My engines the 1.6e btw.
I used to have a Green induction kit but wasnt impressed. Also had a Green twister but that was pretty crap too, even if it was supposidly heat shielded.
A friend sent me the K&N kit and its much better IMHO. Better pick-up, sound etc. Go for K&N or pipercross... forget Green - the quality is abismal.
