Alpine 9812RB wiring help
  K20 EG Hatch
How do you wire this so that you dont have to wire from the battery and so it works off the standard loom and keeps the settings etc when the ignition is turned off?
I know it can be done and will be installing tomoz afternoon so please help!
muz
  big fat japanese bus
the high amp alpines have a battery live for a very good reason as it has a big current draw. You need to wire it to the battery, its really really easy though!
  K20 EG Hatch
it says though only needed if ur using the internal amp; which i am not!
I will be turning the internal amp off and using a seperate amp.
