Alternative to SRP ?
  tiTTy & SV650
I think SRP is goodstuff its not a cleaner as such though, is that not an alternative to mequiars stage 1 deep clean stuff?
  Mito Sportiva 135
I've got this stuff, I like using it. Not sure if there is much difference between it and SRP, maybe a bit easier to use, leaves a very good finish and smells of LEMONS...MMM!!!
Its good to use by hand though.
  106 GTi
There is no real alternative to SRP, Klasse and Jeffs come close but neither have the small amount of abrasive cut the SRP has, most other pre wax cleaners are not comparable directly to SRP as they lay down no protection.
I would not use the Sonus after SRP.
  Fiat Coupe 20vt
The main difference is it doesn't contain any protection like SRP. It's a p[aintwork cleaner which leaves in my mind a glazed finish.
The closest thing we sell and I think is better than SRP is Carlack Nano Systematic Care. THis is the Original product from Germany. Both Klasse and Jeffs are simply re-bottled Carlack for a American market. It's as such much better value as it comes direct from the factory.
For LSP the Long Life sealant is the same product as Jeffs you can add distilled water to it to make it sprayable, like the Jett.
Works a treat as a paintowrk cleaner.
This is on a 'clean' car.
It also applies nicely by PC:
  106 GTi
The Carlack/Klasse loses out to SRP due to the lack of any abbrassives, the ones in SRP be it very mild are a added bonus over it IMO. If the Carlack had them it would be perfect. SRP is also easier to use.
