S13
Hi,
I'm having trouble with my amp, it doesn't seem to want to power on at all. I was just wondering does it actually need to be fully plugged into the remote on switch on the headunit to turn on? Reason for this question is that I've run the power cable from the battery to the boot and just to test it today I plugged it and it doesn't work (it is grounded correctly and it has a little green light on it that shows if it's on or not which doesn't light up) I only bought this amp to replace one which I assumed was broken which has been hooked up completely. What am I doing wrong? I can't seem to find any fault in the wiring.. What generally needs to plugged into an amp for it to operate even if it doesn't put any sound out or whatever?
Cheers,
Rob.
Cheers,
Rob.
