anyone good with formulas on excel
  Hyundai i40
brought some work home for the 1st time ever
i need to do a kinda merge between a lookup and an IF formula
im working between two spreedsheets
if the value is less that 0 it needs to take a value from one column and pull it in to the other spreedsheet and if its more than 0 it needs pull in another figure from another column
the things is both sheets arent in the same order.
i know you can use VLOOKUP to pull in the figures under the same name and IF formula to use a true/false thing for above or below zero
im looking for a formula to pull these both together
can anyone help?:)
thanks if you can
  340i
ooohh havent used excel formula's for a couple of years now...
Let me have a look through some old lectur notes LOL
MarkCup
Instead of trying to put it all into one formula, break the formula down into its component parts, with each part in its own cell.
If I'm doing something complex, it makes it easier to pull together that way, being able to see each bit in its own column.
When you finally get the result you need, either write out the formula as one in a new cell before deleting all your workings, or just hide your 'workings' columns leaving the result column visible.
  Hyundai i40
good idea Mr Cup.......i think i was making it alot complicated than it should be
Gave up after 10 mins so will get cracking in the morning:)
cheers matey
