AUX to Bluetooth transmitter
  Renault Clio MK2
Does anyone know any somewhat decent bluetooth transmitters that plug directly into the aux port and don’t require being plugged into a cigarette lighter or use a battery?
Rich-D
  E90 LCI 330d
Receiver surely, assuming you want to play music from your phone via Bluetooth and into the aux?
If so, unless you get one that either plugs into a power source or has a battery, how do you expect it to work?
hopgop1
As above, a 3.5mm in doesn't provide any power for a transmitter to run off. What clio do you have (presumably not a mk2 due to the aux port?), someone may be able to recommend a better solution.
Darren S
I bought a recommended Pioneer head unit and adapter box a few years back for not a lot of money at all.
Streams from my phone seamlessly. DAB radio, decent enough settings (for me anyway) and works completely with the integrated stalk controls. I'd personally go down that route - more so as a lot of people have already done it.
Rich-D
  E90 LCI 330d
I've done headunit swaps in the past, I also had a Pioneer with integrated bluetooth, improves the sound too even on stock speakers.
But if you want to keep the original headunit, get something like a Parrot bluetooth kit which is hidden away?
  Clio Williams 2
Can anyone provide a link for the Pioneer head unit swap they did that works well with the stalk controls please.
Appreciate it will be a little aged, but just some ideas would be good.
hopgop1
Mk2 Clio? If so, you’ll need a connects2 box for stalk controls, but which one depends on if your original stereo is an update list or tuner list. Have a search on here, but I believe with that adapter box the stalk controls should work on any standard head unit you swap to, as it’s just ISO harness.
  Clio Williams 2
Thanks for you help
