Back brake discs and pads
  Renault Clio Sport
Hi
I have a 53 172 Clio sport and i need to know a few things about the brakes
1) What is the minimum depth for a brake disc
2) I have serated discs at the moment, i am just a road user, do i need to maintain these or can i go for the normal discs as there seems to be lots of different ones and the prices vary.
3) Is there anywhere where i can find how to change them
Please help
Yodabear :rasp:
  LY R26, LY 182
Not sure about the minimum width for the discs...
What is a "serated disc"???
Just go for standard discs or upgrade to Brembos if you are a road user (G172 on here is the best price I found). I've just changed my brakes to Brembo vented (not drilled or grooved - just solid) High Carbons on the front, rears with bearing pressed in and brembo pads all round. Was a doddle to change them, definitely do it yourself if you are a bit handy. Would recommend you use a torque wrench so you don't overtighten the nuts and bolts!
Go to the guides section, there are a few guides on there, but you need to be paid member... well worth the membership fee tbh as you'll save a bundle in garage fees!
  Renault Clio Sport
Sorry i meant grooved girly error lol.
Where can i find those discs, i have the grooved ones and defo dont need them, could you provide me with the link for the best one
Ta muchas
Yodabear
  172 cup, Impreza P1
Minimum rear disc thickness is 7mm and centre nut torque is 175nm so use a torque wrench.
