Background removal tutorial
Knuckles
Here's a very quick, very rough guide for anyone wanting to remove backgrounds in photoshop or similar.
The app I use is called art studio for iOS.
Original image
In the selection tools, I use this one. The name escapes me but it joins up points which you put on the image to make a selection
Put a point down and then start following the profile of the car
I rushed the bottom which goes to show that time = quality and the more points you put in the better it'll look
After you have your selection, find 'inverse' in the select menu
This will select everything but the car
So when you draw across the image, only the background will be affected, not the bit you want to keep.
put another layer under the car image
