i want to remove the renault diamond from the front and also the renault and the clio badges from the back so i can spray them. can any one advise me as to the best way to do this?
thanks
re the front diamond, is it a ph1 or ph2 clio? as the diamond is different to take off IIRC. judging by the fact that you have a "renault" badge on the back id say its a ph1.
The diamond on the bonnet is held on by 3 pegs as mentioned above. Use a flat head screw driver wrapped in a shirt or something and prise the bottom of it up a bit, then you can pull it off easily. Put some masking tape along the bottom of it too to protect the paint a bit more if you like.
