best place to earth in the boot??
AK
  M240i
I undid a nut that was holding the seat belt clip and slipped the end over that and tightened the nut. worked a treat.
  Ph 1 172
i unscrewed the screw that holds the rear lights in plave put an o ring aroun the earth lead and just feed it though the screw and then did the screw back up!!! if that makes any sense lol
  CLIO PH1 172
not sure what your earthing but will the above be ok to earth the battery if you relocating it??
  Polo + Micra
if you going to relocate the battery i'd drill a new hole for the earth as you will probably be drilling for a battery tray anyway
  Golf GTD Mk7
use the ISO fix bar bolt holes maybe? make sure the surface is sanded down to bare metal also.
  CLIO PH1 172
this is what i was going to do anyway but if i could save drilling another hole in the floor i would lol
  Mk2 172
NO NO NO NO NO!!! Drill a hole, thoroughly clean paint off and nut and bolt it! Do it properly end of :)
hi sorry, me and many others have asked but thers been nothing official just through pms and ive been seraching many threads and it just routes me down the ''oddesey race battery under passenger seat''
im looking to keep my standard battery and relocate it to the boot as many others have done, ive been given a rough list of what i need, but where to get it all from specificly would be great!!
a list of what i need and where to get it from? thankyou!
