BIG PROBLEM AGAIN!!!
cant believe this..wife has just come back and said something is wrong with the car at 5,000 rpm...went for a spin and yes at 5,000rpm massive banging sounding coming from front/underneath car...could this be the exhaust sounds bloody aweful but only at 5,000rpm plus..what the f is going on..this car is a bloody nightmare...help me for suggestions when the car goes in 2morra
oh and i suppose that dont really help, sorry, someone had this prob i think! see the thread "cup 3/4 fixed" mayb??
  Burgandy 174 sport t
Cuppy wen i had a test drive in one last week @5000rpm it made a kinda rasp from the exhaust but it came on very sudden
thanks big iain thought that to mate but this is MEGA somethig wrong sound...jay are both covered under warranty..the bloody thing was only in a couple of weeks ago!!!!!
  172 cup,s2 rs turbo
if the noise is that bad then it should be covered under warranty.Engine/gearbox mount definatly covered some parts of the exhaust may not be covered after the vehicle is over 12 months old(but there would be a contribution from renault anyway i should think)
Rich-D
  E90 LCI 330d
Most likely the exhaust moving under the car and hitting the floor...
If its just suddenly done it, check all the rubber hangers on the exhaust as one has probably come off!
They make this noise if you launch hard when 1/4 miling too.
  Elise/VX220/R26
get it into renno and slay them on the spot if they say the dreaded three words..........."no fault found"
  172 cup,s2 rs turbo
theres now way you could say no fault found to cuppy(its something on the transmission side i dont know how he managed to drive it down).what have they told you it is anyway cuppy?
  CTR EK9 turbo
About 90% of 172 owners have this problem: do a search under banging under acceleration. It is the engine mount beneath the battery that has become loose and needs tightening. Ring SMC Renault Woking to find out how common this problem is - if your garage cant fix it get them to call them and talk to tech bloke - they advised a mechanic VR6MAN used to fix his and all is fine.......
SMC woking number is: 01483 720322
hope this helps (in fact this will help, so do it!)
Si
  172 cup,s2 rs turbo
this isnt nothing small like a engine mount(all the mounts are tight and ok).this isnt the commen knocking noise that you all get.this is the first 172 ive heard/felt do this.
cheers si thanks for that advise mate? hey up jay they called my wife on friday and said the good news is they have heard the noise (no sh*t) the bad news is looking at the end of the week until this is sorted..dont give a damn as long as the car comes out ok..they said they have fitted new driveshafts to the car which took all day but when they test drove it it was still there but best of all worse!!! what have they said about it jay? what do you think it could be???? just my luck to get the first car that does this!!!!
  172 cup,s2 rs turbo
they have fitted new driveshafts but it didnt cure it. i think it might be a gearbox(differential) problem but they are going to recheck it this week.
did they take the new driveshafts of it then? wot kind of job could the gearbox problem be then? im i gonna be without the car all week mate? have you worked on my before..were you there when i came through to look at the rear brake bias thingy boby??
  172 cup,s2 rs turbo
theyve the left new shafts on because the old ones were faulty but something else had damaged the shafts.i think ive had something to do with your car but it was quite a while ago and i cant remember what it was.the past few times its been in i havent done it.seen you when you came in cos i found the paperwork for the front desk to show the spring isnt fitted.
