Brake question.
  Clio 1.6 16v Dynamique +
Quick question. Will the servo work if the engine isn't running just with the ignition on? Thinking of towing another clio but the engine doesn't run.
Thanks.
Debz XXXxxx
tow it as normal and press the brake pedal, you need to push it a bit harder but unless your a cripple you can stop it fine.
No offence meant to cripples btw
Ah. So it will react like a car without a servo. That's ok I suppose as long as I can keep the preasure on. (Have a problem with Arthritis). I might have to consider something else being as it it quite a way to tow it. (it's in essex and I'm in Surrey).
Thanks . :D
MRBILLYUK
  FF Jeden Osiem Dwa
It can be a bit dodgy with no servo even pressing the brake hard if your being towed on a rope , you might need to use the handbrake a bit ;)
