Buzzing-humming noise at 4300rpm to 5000rpm
  Clio II 1.6 16v 2001
The buzzing (like a very bad wheel bearing) is only when I'm in gear (doesn't matter which gear) and it starts from 4300rpm to 5000rpm, after that the resonating sound is gone.
I checked:
1, the clutch cable
2, the exshaust, and the heat covers?
3, i replaced all the engine mounts
4, i have replaced all the wheel bearings
5, i replaced the driving shafts too
I could really use some help, where should I look for the problem.
Thank you!
