Can't get my speakers to work PLEASE HELP!
  CLIO 182
Can't get my speaker to work, I was driving with the music low and then the speakers on the drivers side of the vehicle then stopped... The passenger ones work fine, so I have took them both out and checked them over the speakers are fine and I have checked all of the fuses in the car and they are fine also, I could think of what to check next has anyone got any ideas?
  Clio 182
No fuses for speakers, did swap speakers over to test? Generally it will either be a broken cable @ door jamb, or loose cable behind stereo which would cause such a fault.
  Polo + Micra
if it's the standard speakers, set the balance to the drivers side and see if the tweeter is working
if not start at the stereo if it is working start at the door speaker
