182t
My 182 inferno that didn't run went into Engine dynamics a few months back now
It started as low boost kit and ended up a tad more
I'm going to put up spec list
And videos and photos
Once engine has been run in
Hopefully be useful to anyone interested in doing this in the future
Car has speed line turinis,, ktec exhaust pippercross induction kit and Apex springs haha
Apart from that it's just minor aesthetics
T28 / T25 Hybrid Turbo Charger
Turbo Oil Feed pipe
Turbo Oil Drain Pipe
Turbo Exhaust Manifold
Turbo Exhaust Downpipe Kit
Turbo Intercooler kit with Black Alloy Pipes / silicone hoses
K&N Air Filter with our Intake Kit
AEM FIC ECU and Custom file for OEM ECU
Larger Fuel Injectors
High Volume Fuel Pump
Forged Piston Set
ARP Con-Rod Bolts
Head Gasket Set
Head Bolt Set
Lower Gasket and seal set
Timing Belt Kit
Uprated Clutch Kit
Spark plugs
One way valve for carbon canister
Alloy Turbo Heat shield (Copied from ed)
Optional Extras where
Forged Con-rod upgrade
Cylinder Head refurb with new, seals, gaskets, hydraulic lifters etc.
New Aux Belt Kit and Dephaser Pulley
Upgraded ECU with switchable maps and interior mounted switch
New alternator
Painting of cam covers and intake manifold orange and black
Engine rebore
Regrind crankshaft and oversize bearings
Cylinder head refurbished
New cams
Oil Pump
Toothed crankshaft pulley
Front Lambda Sensor
Cat - manifold Gasket
Front top rear brake pipes
Rear Brake pipes
Wiper Blades, front and rear
N/S Outer CV boot
Front brake calipers
Minted pads
Front and back brembo hc grooved discs
Braided brake lines
I have ordered updated engine and gearbox mounts
Apart from Coilovers hopefully should be finished
Turbo Oil Feed pipe
Forged Piston Set
ARP Con-Rod Bolts
Head Gasket Set
Head Bolt Set
Timing Belt Kit
Uprated Clutch Kit
Spark plugs
New alternator
Engine rebore
New cams
Oil Pump
Front Lambda Sensor
Rear Brake pipes
N/S Outer CV boot
Minted pads
Braided brake lines
