Car not starting sometimes
For no apparent reason. Sometimes I get in and it's fine, sometimes I get in and it tries to start for a couple of seconds then just goes off. Try again, and it does the same. Leave it for a minute, it does the same or starts randomly. No warning lights on dash - any ideas?
You know when you say it doesn't start, when you turn the key to start it, is there no nothing there, i.e nothing even trying to fire/start?
Mine did this on the Cat&Fiddle meet, BenP fiddled with the sensor that's under the bonnet then it started.
TDC Sensor?
Mines does this. Doesn't start after a long journey or when its hot. Took the TDC sensor out, used carb cleaner on it, put it back and its been fine since
Tries to start for a couple of seconds then just stops on its own. Had the TDC sensor replaced with the new one + loom not too long ago, but could maybe be that it's got dirty.
What would I be looking out for to find that out mate?
Sometimes, I turn the ignition and it won't start, so I turn it further for a second and then turn it back off, then on and it'll start... but only sometimes.
