Changed thermostat - leaking!
Greg.w
  Focus RS
Evening all,
Swapped the thermostat out recently and first time starting the car noticed it weeping around the 3 bolts where the thermostat is fitted.
It was a febi part I fitted that came with the rubber gasket.
It's such a simple job, old one out, new one in and do up the 3 bolts.
Have I done something wrong? Gasket looked good when I fitted it.
Greg
Greg.w
  Focus RS
Make sure the mating surfaces of both are clean from Ali oxidation and dried up coolant as well.
I gave the front a wire wheel including the bolts so that was like new, gave the internal a good clean too. Everything was spotless. I'll whip it off tomorrow and see if anythings fowling it. Failing that I'll put a bit of rtv on the face.
Greg.w
  Focus RS
Sorted tonight with a tiny smear of rtv on the face. Only lost half a litre or so of coolant (changed the coolant less than 1 mile ago) so not too difficult a job, took about 10 minutes.
Thanks for the replies 👍
