changing the bulb for the valvers external temp display
If I remember correctly you need to take the steering column shroud off by undoing the 3 screws underneath it and removing the two halves. You also may need to take the panel off below this (I can’t quite remember) to get access to a couple of screws holding the dials in from underneath. Undo the top screws on the dials as well then pull the dials forward and get your hand behind to release the speedo cable (I think there is a little catch on it), unplug the other multiplugs on the back being careful not to damage the printed circuitry on that back!
