Don't think so, I recently did it though.
Not *that* hard....
Crack hub nuts loose while on ground
Remove bumper
Remove headlight
Remove battery
Remove airbox
Drain box
Remove uprights
Remove driveshafts
Remove all plugs, earths etc
Loosen lower gearbox mount
Loosen gear linkage at box
One by one replace subframe bolts with threaded rod/nuts
Loosen steering shaft to rack nut
Support box
Remove tripod bolts
Lower subframe about 2inches
Remove bolts from box
Loosen box
Move box away from engine
Change clutch
Reverse
I think that covers it....
