Cheap Mig Welder £99 NO Gas
G_F
  BMW M3 & Williams 3
3 year guarantee aswell, this is half the normal price, getting myself a few i thinks.
http://uk.aldi.com/special_buys/productnl_212.html
Thursday Special Buys
24th May 2007
You can find further information
and offers on our homepage
No Gas Turbo Fan-cooled MIG Welder 25-130 Amps
each £ 99.99
For those longer, heavy-duty welding jobs both indoors and out, this portable, turbo fan-cooled ‘No Gas’ MIG welder is ideal.
Accessories include: 0.45 starter spool of 0.9 flux steel wire, leads, chipping hammer/brush, earth clamp, welding torch, hand-held face shield.
  • No gas: No need for expensive gas cylinders. This machine has the benefit of using a flux cored filler wire which creates its own shroud of gas whilst welding. Ideal for working outdoors as well as in the workshop.
  • Non-live torch: For optimum safety and control, the welding torch only becomes live when the trigger is depressed.
  • DC power output: For smooth, easy to control ‘cool’ welding, this machine produces a DC welding current – normally only found in far more expensive machines.
  • Wide output power range: This welder operates between 25 amps and 130 amps DC.
  • 4 power settings: For versatility and excellent results.
  • Turbo Fan-cooled: Extended duty cycle with benefit of fitted turbo fan cooling.
  • Thermal overload protection: Maximum safety guaranteed.
  • 230V/13 amps: Use from a standard domestic socket* (plug fitted).
  • Fully portable: Carry from job to job (weight 18kg)
  Lionel Richie
no gas mig welders are rubbish, you'd be better sticking stuff together with glue
unless its just for hobby stuff i wouldn't bother
G_F
  BMW M3 & Williams 3
I thought 'gas' was so 2005..What would you reccommend Fred for first time use? welding bodywork,sills etc
